Koffie in de krant of op het web
Berichtdoor bobbee » di 10 okt 2023, 16:50
Wie had dat gedachtDeze kan zo op de website van De Speld! Afbeelding
Ja, zo kunnen wij er ook wel wat verzinnen
Hobbyvisserij blijkt samen te hangen met beschadiging van vissenbekken
Bedlegerige mensen komen zelden bij spoedeisende hulp met gebroken ledematen, tenzij ze uit het bed zijn gevallen.
Baanbrekend onderzoek wijst uit dat de buitentemperatuur invloed heeft op persoonlijke kledingkeuze van de mens.
Berichtdoor fransg » zo 15 okt 2023, 15:26
https://edition.cnn.com/2023/10/11/busi ... index.html
New York CNN —
Drinking bad coffee is just one of the many downsides of flying. Alaska Airlines thinks it has a solution.
Alaska has created a custom blend with Portland-based roaster Stumptown to make a coffee that’s immune from the altitude-changing effects that airborne-served coffee typically creates, including tasting bitter and weak.
The custom coffee, a first for a major airline, will exclusively be served on every Alaska flight, including its regional carrier Horizon Air, by December 1.
Taste and smell are inextricably combined and people’s sense of smell is significantly altered in the sky. Food and drinks taste different because pressurized cabins lower blood oxygen levels, which reduces the ability of olfactory receptors (i.e. the ability to smell). The extremely dry air of the cabin, with its humidity levels lower than that of the Sahara Desert, also affects the nose.
To combat those effects, Alaska turned to Stumptown’s Holler Mountain, a medium-dark blend, for the base, then infused it with punchier notes that taste like marshmallows, browned butter and toffee as well as a “delicate hint” of citrus oils and cherry essence. As a result, the coffee’s notes have a more “complex” taste when consumed in the air.
The coffee has been in development for a year, with the airline telling CNN that 20 different versions were tested, including during flights and with blind surveys. Alaska even taste-tested the blend with creamer and Biscoff cookies to “ensure the best combination.”
However, the freshly brewed partnership with Stumptown means that Alaska is ending its decade-long partnership with fellow Seattle-based coffee company, Starbucks. Alaska said it is “grateful to our friends at Starbucks and proud to have served their coffee on board our flights for years.” (Delta Air Lines, which has a major hub in Seattle, still serves Starbucks on its flights).
“Airplane coffee is often a joke for many travelers,” Edward Russell, editor of the Airline Weekly newsletter for travel industry publication Skift, told CNN. “That’s why airlines often try to up their game with various global coffee brands; despite that, most onboard options are mediocre.”
He added that he doubts the custom coffee will attract new customers to the airline, but the new partnership with Stumptown “looks more like what the airline does best,” which is boost businesses from the Pacific Northwest. Other regional companies served on Alaska include Tillamook cheeses, Salt & Straw ice cream and Straightaway canned cocktails.
Berichtdoor fransg » di 31 okt 2023, 12:16
gilleko B.
Berichtdoor gilleko B. » di 31 okt 2023, 14:17
Dat doet me denken aan a knife a fork a bottle and a Cork
Nelus
Berichtdoor Nelus » za 04 nov 2023, 13:33
https://www.instagram.com/reel/CzLIFEOx ... BiNWFlZA==
99% kans dat je gaat lachen. Wel even volhouden tot de ontknoping :mrgreen:
Faema Lambro - Mazzer Major E
Berichtdoor bobbee » ma 06 nov 2023, 22:27
Berichtdoor fransg » do 23 nov 2023, 14:19
fob
Berichtdoor fob » do 23 nov 2023, 21:05
Alweer jaren geleden gepubliceerd in het medische tijdschrift "The New England Journal of Medicine", maar het artikel Association of Coffee Drinking with Total and Cause-Specific Mortality kwam vandaag voorbij in een praatje op mijn werk. Het is een studie naar de gezondheidseffecten van koffie, met als conclusie dat koffie het risico op overlijden door zo ongeveer alle oorzaken verlaagt. Het effect is dosisafhankelijk, dus meer koffie drinken betekent een gunstiger effect. Doe er je voordeel mee. Met of zonder cafeïne maakt niet uit.
Quickmill 820 met 9 bar OPV en precisie filterbakje mod - Quamar T80 met single dose bellows en doserless mod - V60 - Aeropress - Handpresso - I-Roast 2 met verlaagd vermogen mod
ErikvW
Berichtdoor ErikvW » do 23 nov 2023, 21:41
... Met de specifieke annotatie dat als je koffie gebruik leidt tot enige vorm van slaapgebrek of verlies van kwaliteit van nachtrust, alle positieve effecten teniet worden gedaan. Maar inderdaad best verrassend dat iets dat zo lekker is, ook goed voor je is. In een podcast kwam ook naar boven dat er veel vezels in koffie zitten.
Bezzera Strega - Niche Zero - Umikot Planetary Distribution Tool by FrancisPavoni - Puqpress - Aeropress - Aergrind V3 - Puckrake (gold edition) by ArjenT5R™
Berichtdoor fransg » do 14 dec 2023, 19:18
Gebruikers op dit forum: Geen geregistreerde gebruikers en 11 gasten
cron
