Beam me up, ScottyIntroducing a brand new product to the Acaia line-up: the Ion Beam.
Designed to work with the Orbit and other coffee grinders, our latest accessory solves the common problem of static generated during the grinding process.
The Acaia Ion Beam features an industrial-grade ion generator that effectively minimizes static generated from grinding, leading to lower retention, less flying chaff, and fewer clumps. This is achieved by releasing a stream of charged ions that neutralize the charge that builds up during the grinding process. The Ion Beam generates negative ions on the front end and positive ions on the back. It can be adjusted depending on the coffee's charge.
Acaia Ion Beam
Acaia Ion Beam
Berichtdoor robinfcb » di 18 apr 2023, 21:54
Acaia brengt een apparaat op de markt om statisch koffiepoeder te voorkomen. 150 USD: https://acaia.co/blogs/news/new-product ... e-ion-beam
🟤 Ascaso Steel Uno PID × Hedone Honne × Superkop × NanoFoamer PRO 🟤
