As far as I understood (by using google translate):
Our Wifi-Controller (an ESP32) is also able to communicate by Bluetooth. But actually there is no setting to switch to BT. May be we offer it in the future as it is essential for some countries.
Actually there is a project started with another company. There will be a scale and an app and both together it will supply 'volumetric control'.
Xenia with 2 boilers and powercontroller
Re: Xenia with 2 boilers and powercontroller
Berichtdoor iskanda » vr 07 apr 2023, 08:32
Yesterday we finished a new model of the Xenia with 2 Circuits. It uses the same control unit of the Xenia with 2 boilers.
There is now also a webinterface and pressure profiling (with scripts) possible. And it works more also (more) silent due to the reduced power for the pumpe.
Here is a 1st extraction (of teh 1st machine which is still open and a bit more noisy).
Video: https://youtube.com/shorts/TQyqk_qNlK8
Berichtdoor XeniaEspresso » wo 20 mar 2024, 17:17
In the meantime we delivered some machines to customers in the netherlands.
Here is a video of a machine and you can see that the machine is very silent for a machine with vibration pump:
youtu.be/kvXW_Fe-uUw
We added now a shipping option to the configuration tool. Actually it is needed to use the german configuration tool: https://www.xenia-espresso.de/x24/
In some weeks, there will be again an english version available.
Berichtdoor XeniaEspresso » zo 24 mar 2024, 15:54
Berichtdoor XeniaEspresso » zo 24 mar 2024, 15:56
Berichtdoor hifivoice » zo 24 mar 2024, 17:14
Ik heb deze dual-boiler al bijna een jaar, en gebruik 'm ieder dag met plezier.
Heb er een profiel in gezet die de druk in een paar second opbouwt, en na een seconde of 20-25 langzaam afbouwt, zoals je dat met een hand machine zou doen. Smaakt verschillend van in een keer de 9 a 10 bar erop zetten, en daarna eraf te halen.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 43 gasten
