Re: ARGOS van Odyssey Espresso
101
Odyssey Espresso
Argos Update: November 13, 2023
Hello All,
Shipping Updates
We’ve currently shipped 60 units, have 24 more ready to be boxed, and 3 that need additional attention. Now that all of our previously built machines have been updated several times and QC’d, we’re excited to start building new stock from the ground up with all of the lessons learned over the past few months of assembly. This process should continue to get smoother and no longer require multiple rounds of disassembly and checks on top of the standard QC process.
Hardware Updates:
Our biggest issue continues to be LED consistency. I’ve done way more research than I ever thought I would need to on LEDs, worked with our supplier, and performed internal testing to come to the conclusion that our current supplier uses lower quality semiconductor chips than is acceptable for our production. I’ve reached out to 3 new suppliers all with great reputations, ordered samples from each, performed endurance testing on 50 - 100 LEDs from each, and placed a new production order with the lights that we liked the best. While these LEDs are still 2 weeks out, we will continue building complete machines with everything except the LEDs and add those in for final testing when those arrive. This way we won’t slow down production testing and fixing bad lights, but we also will continue making progress on assembly. We will be reaching out to anyone with a bad LED regarding next steps for fixing.
Overall, customer feedback has been very positive! We recognize there is a bit of a learning curve with levers as a whole, but more specifically, bleeding air out of our piston bleed valve can take time to get right. Improper air bleeding on the Argos results in lower extraction pressures. We’ve spent the past month prototyping our restrictor orifice as mentioned in previous email updates. We’ve landed on a custom integrated pressure compensated flow control valve. This valve not only restricts flow into the grouphead to automatically bleed air out at the correct rate but also maintains consistent flow regardless of boiler pressure.
We’ve also been working on a few other small changes such as improved fill funnel to make it easier to determine fill level and an anti-vacuum valve overflow reservoir. It’s normal for all anti-vacuum valves to drip a tiny bit of water out when closing. We’ve found that overfilling the boiler causes the valve to prematurely close leading to false pressure and excess water to drip out of the valve. Adding a reservoir will be a simple added level of security to prevent damage in the event of accidental overfilling. This reservoir will include a filter to allow any accumulated water to evaporate during normal use or in the event of continued accumulation will overflow out of one of the vent slots in the back cover of the machine.
Replacement transducer batteries will very soon be offered on our website. It is disappointing that the batteries used in the transducers we use are not a common, off the shelf part. The batteries can be found, but only with a different connector. I’ve sourced the correct connectors and ordered some batteries for testing but we aim to offer a replacement for lower cost $25USD + shipping and will also create a video to show any DIY customers how to get off the shelf battery parts to work for ~$10 USD + shipping.
Sincerely,
Ross & William
De eerste kopers blijken toch een soort bètatesters. Pas 60 apparaten uitgeleverd. Denk niet dat we dit apparaat vaak op de Nederlandse markt gaan zien.
Meticulous Espresso × etzMAX LM × Hedone Honne × Pietro Probrewing × Superkop
103
Gelukkig zit ik niet zonder espresso maar sinds Maart 2022 is een lange zit, en we zijn er nog niet…. Maar dat ze aanpassingen blijven doorvoeren en participeren op discord blijft mij vertrouwen en hoop geven. April 20** zal hij een keer op mijn aanrecht staan.
106
Mooie review en ook tegelijk een instructiefilmpje.
Begrijp ik nu goed dat hij bij een hete groep, en dus lage boilerdruk, de druksensor gebruikt terwijl hij de hendel gecontroleerd iets omhoog laat komen om dezelfde pre-infusiedruk te creëren?
Ik heb zelf alleen de analoge drukmeter besteld, maar dat zou hetzelfde moeten werken neem ik aan.
Ik zal het nog een tweede keer moeten kijken om alles mee te krijgen. En dan nog een keer de unfiltered versie als die online komt! :D
Odyssey Argos - Lagom P64 - Hario Switch
107
De temperatuur in de groep stel je op de zijkant van de machine of in de app en dan overhit de groep niet.
De groep temperatuur wordt dus door de pid met druk in boiler middels aan/uit in balans gehouden. Maar voor het eerste shot (veel druk) zal het vullen en pre-infusie in de groep dus anders zijn dan het laatste shot uit de boiler (weinig druk). De bleed valve zorgt ervoor dat je de lucht tussen de piston en puck kunt afvoeren en meer volume hebt. Bij meer dan 1 bar boiler druk zul je dit waarschijnlijk alleen gebruiken en daarna niet meer. Ook lijkt het zo dat de bleed valve ervoor zorgt dat je een fellini voor meer volume kunt doen zonder dat je de puck aantast.
Lekker theoretisch allemaal, hij mag van mij nu wel eens komen. Ze zijn nu tegen de 500 en ik zit in 600….
