Deze:omeCo schreef: do 13 jul 2023, 07:29 Dit is het zeefje dat de geest heeft gegeven.
Onderstaande tekst gaat over het hoe en waarom van dit specifieke zeefje. Ook het onderhoud komt aan de orde.
“Having spent a considerable amount of time testing this screen side by side with the IMS 200 micron screen i am comfortable that this screen is better at arresting the surge of water into the brew chamber as the rising piston clears the inlet ports. We have added holes to the centre of the former that sits behind the 35µM mesh to promote water flow through the centre of the puck as a lever group naturally delivers a higher flow at the circumference of the group
If the shower screen fails to arrest the water surge into the brew chamber the incoming water is likely to carve a channel right through the puck. This is much more of an issue with lever machines as the brew chamber is filled with water almost instantaneously, whereas a pump machine chugs away for many seconds to get the job done
This is a specialist lever espresso machine screen
When the screen starts to pop off the group this is an indication that an area of high pressure is forming above the screen, the result of some of the holes in the screen being blocked and you need to remove the screen from the group and clean it with a cirtus solvent or similar, then rinse in copious amounts of fresh water and refit the screen
Shower screens are a consumable item and can be expected to have a service life of 3-4 months even in a domestic environment. A clean screen has a significant impact on the quality of the extraction you achieve. If you are the kind of owner who likes to tinker with something on your machine regularly to extract the best coffee possible then the shower screen is the one item that needs to be replaced regularly”
Je maakt een prul en vervolgens verklaar je dat dit normaal is en jij een kluppel bent dat je dat niet snapt.
Erg triest dit soort verkooponzin.
Ik heb showerscreens van 10 jaar gehad die nog perfect zijn.
Is een trend. Rotzooi maken waaraan niet gerepareerd kan worden. Zodat je bijvoorbeeld een nieuwe wasmachine moet kopen omdat een onderdeel van 12 euro kapot is.
Verdienen ze lekker aan en dat het milieu hier zwaar onder te leiden heeft is van generlei belang.
De perversie van het consumptisme ten top.
Nog zoiets.
Electrische autos. Ooit bedoeld om CO2 uitstoot te beperken en zo het tanende klimaat nog een schijn van een kans te geven.
Verworden tot het zoveelste verdienmodel van de auto industrie.
Je hoort niemand over de groteske bakbeesten die tegenwoordig uit de autofabrieken rollen. De een nog groter dan de ander.Zelden zulke slagschepen gezien.Alsof de autofabrikanten een dikke middelvinger naar de milieubeweging opsteken .Dat besparing van grondstoffen en lichtgewicht auto's onderdelen van het klimaatconcept zijn zal wel bij de concerns zijn doorgedrongen maar men doet alsof de neus bloedt.
Ik zou nooit zon electrisch gedrocht willen hebben. Een klein electrisch autootje van 800 kilo ja. Niet zo'n vliegdekschip.
Zo'n IMS screen komt er bij mij dus ook niet in. Fuck the company zeiden Harley rijders vroeger toen de motorbouwer uit Milwaukee overstapte op een ander motorconcept waarbij men ook steeds zelf minder makkelijk dingen kon repareren.
