Gisteren ´live´ gegaan.....
http://home.lamarzoccousa.com/linea-mini/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
$ 4.495
Color Options
Stainless, Black, White, Red
Main Features
Groups 1
Boiler Type Dual Boilers
Pump Type Single internal rotary pump
PID Temperature Controller Yes
Indicator Lights Heating and Water Level Lights
Body Panel Stainless Steel
Specifications
Height (in) 15
Width (in) 14
Depth (in) 21
Weight (lbs) 71
Voltage (VAC) 120
Amperage (A) 15
Element Wattage (W) 1600
Steam Boiler (liters) 3.5
DUAL BOILERS
Separate boilers optimize espresso brewing and steam production.
INTEGRATED GROUP
A combined boiler and brew group achieve thermal stability in a reduced footprint.
HOT WATER SPOUT
Convenient spout for rinsing portafilter between shots.
THERMAL STABILITY SYSTEM
As water passes through each feature, temperature is further stabilized.
BREW PADDLE
Brew paddle activation with programmed pre-infusion creates delicious consistency from shot to shot.
INTERNAL PUMP
Self contained rotary pump without compromising performance.
PID CONTROL
Stepped temperature wheel allows for user adjustment.
WATER RESERVOIR
A self-contained 3.5 liter water reservoir makes plumbing optional.
BARISTA LIGHTS
LED lighting allows you to focus on your extraction and the cup.
RUBY FLOW RESTRICTOR
Ruby flow restrictors resist scale formation and erosion.
NIEUW: La Marzocco Linea Mini
1Ah! How sweet coffee tastes, more delicious than a thousand kisses, milder than muscatel wine.
The Coffee Cantata - J.S.Bach
