Levensduur (kleinere) onderdelen half-automaat.
Code: Selecteer alles
http://coffeetime.wikidot.com/maintenance-of-espresso-machines
The machine simply doesn’t last for ever, although most of it will last a very long time, other parts have a shorter life. Common parts and typical lifetimes are shown below
Group Gaskets – about 6-18 months depending on the abuse (and lack of cleanliness) you give the machine
Shower screens (many years, if you keep them clean)
Vacuum Breaker Valves (3-7 years)
Pressurestat (3-7 years)
Vibe Pump (3-5 years, they also weaken with age)
Heating element (3-10 years)
E61 group, but 3-5 years before service advised see here, this is mainly springs, o’rings, seals and gaskets and should cost less than £20)
Electronic 3 way solenoid valves (about 5-7 years, unless you let them scale up and burn out!)
Gicar/Giemmie control Boxes (and similar) about 5-7 years
Cable ties, holding wiring together (about 2-3 years! They get brittle and perish, but easily replaced)
Water and steam valves (conventional type) a long time if you are gentle (3-7 years), the no compression ones eventually wear as well and have a similar lifetime. Replacement of the conventional ones is the usual remedy as they are very inexpensive.
You might be forgiven in thinking that you will have built a complete new machine every 7-10 years, but this is not true, most of these parts are very cheap and easily replaced. The major expense components of your machine, if properly looked after should last a “lifetime”, if you’re very young, then make that a really long time. Also forget any exaggerated claims of reliability, from any source. These components are all pretty standard in domestic machines and are usually sourced from the same place regardless of who manufactured your machine. So best gain an understanding of your machine and if you do the motoring equivalent of checking the oil water and tyre pressures on a regular basis you will be fine. Minor repairs and maintenance repairs are also easy, unless you want to pay a lot of money and send your machine away every 3 or 4 years!
Lijkt dit een beetje te kloppen? Er zijn toch best wel dure componenten bij zoals de pomp en het vermarmingselement? Ik zocht een BFC Levetta Junior te kopen (van 8 jaar oud) en daar zit die prijs voor elk stuk boven de €100. Ik hoop wel de volledige onderhoudshistoriek te krijgen want anders laat ik hem staan, ik moet toch weten welke onderdelen er op vervangen staan? Ik veronderstel dat het vervangen best preventief gebeurt want bij volledig kapot gaan kunnen er een resem andere onderdelen ook beschadigd raken misschien?
Hoe zit het met de moeilijkheidsgraad van deze vervangingen trouwens, zijn er hier zelf geleerde mensen bij die item a of b (en welk) zelf vervangen ipv grote kosten te maken bij een professional?
mvg
Re: Levensduur (kleinere) onderdelen half-automaat.
Hangt af van het onderhoud. Is dus ook geen zinnig antwoord op te geven anders dan dat dat de leidraad zou moeten zijn.
Dit geef je in je andere topic aan.
Christof88 schreef:Ik ken gelukkig iemand die aan de lopende band espresso apparaten repareert.
Neem dus aan dat diegene je alle info kan geven die je nodig hebt.
Erik82 schreef:Hangt af van het onderhoud. Is dus ook geen zinnig antwoord op te geven anders dan dat dat de leidraad zou moeten zijn.
Hey ja, maar is nu net op vakantie. en als ik zeg "ken" bedoel ik jammer genoeg een lokale, betaalbare reparateur en geen vriend die me gratis zijn tijd gunt. Dus de pomp/het verwarmingselement/wat dan ook slijt dan meer of minder naarmate er beter of slechter gebackflushed is/ontkalkt/ander wekelijks onderhoud en zo? Laat ik het anders stellen, wat zijn zo de ervaringen van jaarlijkse kosten voor te vervangen onderdelen en onderhoud in het algemeen bij de forum mensen die hun machine netjes zelf klein onderhoud geven en met liefde behandelen? Ik reken hier nu wel manuren niet echt mee want dan geraken we er helemaal niet uit, en zoals ik zeg valt da allemaal wel mee gezien ik niet naar een €50/uur officiële reparateur ga.
Het is lastig voor hierop te antwoorden omdat die dingen zo afhankelijk zijn van specifieke factoren, dat begrijp ik ook wel, maar als er beweerd wordt dat half automaten soms 30 jaar meegaan dan bedoelen mensen toch niet met €200 kosten elk jaar want dan koop ik wel liever nieuwe machines om de paar jaar. Dit zal een overdrijving zijn, dat weet ik ook wel.
Dank.
Onderhoud zal 50 euro per jaar zijn verwacht ik (ex arbeidsloon). Duurste zijn de waterontharders maar die moet je met elke machine gebruiken dus heb ik dan ook niet meegeteld.
Als je 1 keer investeert in een ritje Hoogersmilde naar Kafko kun je voortaan zelf het onderhoud doen. Zo moeilijk is allemaal ook weer niet. Peter is een van de weinigen die je mee laat kijken en alles uit zal leggen. De meeste doen dat niet omdat ze continu aan je willen verdienen. Zo zijn exact dezelfde onderdelen bij Kafko ook vaak veel goedkoper dan bij de bekende winkels. Kwestie van je adresjes kennen.
Met een volautomaat heb je jaarlijks meer dan 100 euro onderhoud als je hem echt goed wilt houden.
Een DB zal duurder zijn en meer onderhoud vergen dan een SB of HX door de extra electronica. Een PID weer meer dan een pressostaat. Een HX is het meest simpel en effectief met het minste onderhoud.
Baseer je dit op je eigen ervaring?
Het strookt namelijk totaal niet met mijn ervaring. In de 10 jaar dat ik m'n volautomaat nu heb, heb ik er exact €0,00 aan onderdelen en/of officieel onderhoud aan besteed.
Gewoon je machine goed schoonhouden, met een verwijderbare zetgroep als randvoorwaarde, en hij gaat nog altijd als een zonnetje.
